H type roll bar
Alabama
Does anyone have an idea where I can get the H style roll bar than Icon uses. Or something very close? Thanks!
tlc icon roll - Google Search
Yeah, I saw your H Roll bar that sold a year ago. Do you still have the dimensions? Thanks!
This one:
You could make one with two stock bars very easily.
I don't have any dimensions, however, I would have made it taller if I did it again. It was designed to fit under a Bestop soft top and allow the top to go up and down and clear the rear hoop.
Sent from my iPad using IH8MUD
I think it might be better getting two stock bar/hoops and bridge them with two short straight bars.
The stock roll bar has thinner wall tubing than a reputable shop, like Metal-Tech, would use. Just draw up a plan and get one made. It's really a simple design. Mine was just pieces of tubing and some angle bracket.
Poser thought it was .088. While I don't disagree, .088 is not zero.
Metal-Tech uses .120 wall tubing. .240 is more better than .176 in a rollover.
SouthBostonFJ, where did you get the screw on roll cage pads?
Fast Eddy said:
A foot thick would be even better. Maybe .088 is enough. This isn't Nascar. Stock roll bars survive freeway crashes.
I know they do. But if you going to go thru the trouble of welding thicker tube to the stock bar, you might as well build one from scratch.
Those are just stock pads.
