GX460 & GXOR B.S. thread (7 Viewers)
Thanks everyone for confirming, I must be thinking of cabin filters which always come plastic wrapped
@Rednexus via Bell Lexus
A safe vendor for sure :). I got a ton of stuff from them with free shipping around Memorial Day.
This used to be what the OEM filter looks like but looks like they now sell without that pre-filter layer
  • Like
Reactions: r2m
I crushed my left suspension member bracket. They are only 75$ on ebay.
My catalytic converter bumps it every so often.
  • Sad
Reactions: r2m
Im not worried so much about the suspension as I am the transmission. The boat, trailer, fuel, and gear, myself and the fuel load in the truck puts me right at the rated tow capacity of 6500 lbs with surge brakes on the trailer. Only hauling this about 9 miles max, but did make a 123 mile trip to bring it home.
Just so you know, your rated tow capacity of 6500 lbs is with both sway control and weight distribution incorporated.
A reasonable person might add that suspension and transmission concerns are irrelevant, while not being balanced to safely steer or brake with a load may be. I do not claim to be a reasonable person, so I am just passing on what I've heard.
Also, the tongue on the trailer is very long, without some sort of spreader bar, there would be no way to install what you're describing.
I shopped around before I chose my WDH. Specifically because it is used with different tow vehicles and trailers of all types. I've moved my own boats, campers, car and utility trailers (rentals sometimes) of varying weights and designs. This one does all of that.
Below is an image showing an example of the way it is installed in your application.
The configuration in the lower right is what they recommend for boat trailers typically. I've had great luck with them.
Nice looking GX by the way.
@rav8 good information. Those add ons would be beneficial. That section of the manual is written by corporate attorneys, the tow rating itself is from the Engineers. The truck pulled the Yamaha fine, and the surge brakes worked great. Most of the trip was in a deluge and other than the transmission temps, I had zero concerns.
Thats how mine looks. The top cover is a bit askew on mine as well.
I can't opine on the 1UR, but the Yotawerx tune on my GX made a big different in midrange power. I also have headers/exhaust/CAI that probably helped as well. It was worth every penny.
$450. I'm more interested in the updates to throttle mapping and shift logic and potentially power under the curve vs the small bump in max power.
Exactly. I wasn't interested in the tiny power gains either. The shift mapping and throttle response improvements have proven to be well worth the money I spent.
WIsh Thorley would make some for the 460
Fair enough, let us know how it is!
  • Back
