Were you able to use the 470 mount for the Switch Pro or did that not pan out? I thought I've seen a couple GX460s with the Switch Pro mounted inside the sunglass holder, but for the life of me I can't seem to find a kit for it. I've been tossing around the idea of running a Switch Pro after installing my LP9's on Monday since there's no spot to mount their giant switch without drilling through the dash, which isn't an option.
Also, how hard was it to wire your Switch up there? If nothing else I like how you have it pictured. That piece is probably cheap enough to replace after drilling through it. Thanks!
