Build GX460 Adventure Build
Member Build Threads
I picked up the SSO kit for the 5th gen 4Runner. I had to modify it slightly to get it to work but I am happy with the finished product.
did you have to modify the wiring or just hardware like brackets. I need to rewrite my back up cam but unsure about cutting wires. Thanks. Nice work BTW
Were you able to use the 470 mount for the Switch Pro or did that not pan out? I thought I've seen a couple GX460s with the Switch Pro mounted inside the sunglass holder, but for the life of me I can't seem to find a kit for it. I've been tossing around the idea of running a Switch Pro after installing my LP9's on Monday since there's no spot to mount their giant switch without drilling through the dash, which isn't an option.
Also, how hard was it to wire your Switch up there? If nothing else I like how you have it pictured. That piece is probably cheap enough to replace after drilling through it. Thanks!
