GVWR at 6470....that's it?
alia176
Tijeras, NM
So, am I to understand that a fully loaded 80 (people+luggage+gas) + trailer weight can be a max amount of a whopping 6470 lbs? Hell, my 80 weighs more than that on out of town trips :doh: So much for towing that UHAUL trailer!
Where did you get that figure from? IIRC, the Max GVWR including trailer is something like 11000lbs.
On the side of my door! I was expecting a similar number too.
I knew your vehicle was unsafe Ali! :D
Your's weighed in at 6800 lbs right? That's quite a bit...
wight with trailer is GCVW, Gross Combined Vehicle Weight
GVWR - Gross Vehicle Weight Rating witch is the max the 80 with its payload can weigh (80+people+fluids+cargo) no trailer.
The bigger question is...what are the gross axle weight ratings? I know that some will argue and that's fine, but most of the 3/4 and 1 ton trucks going down the road with the 5th wheel hooked up are over the GVWR, however, they are good to go on the axles and GCWR. So I guess you have to decide if you feel safe going down the road overloaded.
I did see that the max trailer weight is 5,000 lbs with the "tow" package in my owners manual. So, let's see 5,000 + 6470 = 10,470 lbs. I'm assuming this is how some folks are coming up with 11,000 lbs or so for a total rating?
Eventually, we'll have to tow some of our junk from IL to NM so I might as well start prepping for this. Let's see...I need to tow a Subaru SVX on a trailer...3500 + 1500 = 5,000 lbs. Towing this combo uphill to ALBQ should be interesting :crybaby: I do have a trailer brake unit on this vehicle BTW.
I was thinking of towing a box trailer from Uhaul to carry all of my garage crap (welding gas, gas cans, aerosol sprays, metal, fab crap, tools, etc). This will either be a 5'x10' or a 6'x12' tailer behind the Grand Cherokee 5.2. The WJ should have no issues with this load.
The movers will move the household stuff...that's gonna be expensive I reckon :crybaby:
Ali
