Welcome to Windrock/Coal Creek OHV Area.
Day 1 we went out and found trail conditions highly favorable to a good time (dry). We piddled on Trail 2 and encountered this nice rock outcropping, so decided to play a little.
We continued on Trail 2, then Trail 16, and then Trail 17. I have some good video that I'll ask someone with a Tube account to host so we can direct link it here.
Here's a picture of our camp area.
The next day we went adventuring and found some additional trails on the East side.
This was enroute to Trail 23, a "double diamond" rated trail. This one was a wicked erosion ravine in the trail; you had a choice of going left which is a narrow ridge with the ravine on your right, and the mountainside drop-off on your left, or going right and risking a steep off=camber 90* turn at the top which would dump you on your side into the ravine. We chose to go left (except Matt, who just straddled the thing and came straight up it!).
Bart flinched and his tail slipped into the ravine. I have a video of the winch/recovery orchestrated by Chris. Fine job, Chris!
The trail continued up and ran parallel to a 20-30 ft cliff for about a mile. This portion of trail was filled with fallen timber, making irritating obstacles to climb. The trail then went up sharply around a hair-pin turn, and had two sluices off the left side, straight up the mountain! Ah, so this is why it is a Double Diamond! We cotemplated returning on Saturday to take it as an all-day activity, as it would have required stacking rocks and winching multiple times...and that was only the 750 feet that we hiked ahead to scout.
Here's two pictures of the downhill/return trip. We all took the "center line" through the ravine...it was only slightly less difficult going down.
On Friday we endured a ton of rain overnight and throughout the day. Matt, Steve and Stump attempted the "gatekeeper" on Trail 15; it was extremely slick...very little traction. Matt and Stump made it through the gate and continued on. The next section was long climb off camber with an eroded ravine on the left side. Stump came up it leaning at what appeared to be 45* !!! His slider was cutting the berm like a Ginsu knife! I didn't get a picture because I was too busy getting the hell out of the way!
Matt powered through it all and over the ledges at the top. Stump gave it a few good attempts but decided to take the winch for the final climb.
Taking a break for lunch, we met up with Lance, Rich, and Dan. They took us to see "Rattle Rock" which is a boulder field that climbs the mountainside, similar to a obstacle at Rousch Creek. We passed it and continued on Trail 21, to a bitchin' rock ledge at a stream crossing.
Rich took Raze-N up the ledge, but the FZJ40 and Dan's 4Runner took the bypass after a few attempts.
Matt conquered the ledge in a few tries, and then Steve came up. It took a few turns, but he succeeded as well. We wonder if perhaps it was this impact that fatigued the shackle hangar which broke on Saturday.
Fast forward to Saturday...more rain overnight and constant rain in the morning. About 10am we headed out for Trail 22, 42, and 43. We got up past the top of Trail 21 (it was gorgeously scenic up there with the creeks flowing high). Steve noted a noise, so we decided to stop and check for what we suspected was a busted shock tab or maybe even a driveshaft starting to fail.
Whoa! it was a busted front/left shackle hangar!
Fortunately, there was a 4Runner guy there with a Redi-Welder, and in the pouring rain, Steve, Stump, Bart, Chris, and Matt combined tool kits to use an air grinder, jack, etc. to get prepared to weld. Using Stump's dual batteries, Chris and Matt laid some unsightly, although effective weld on the metal to repair sufficient to come off the mountain and hit the gravel road, and limp the 62 back to camp.
Back at camp, we used the covered pavilion and Chris' generator, welder, and other tools to redress the repair with more permanent welds. More kudos to Chris!
