Are we limited to OEM hardware for replacement of non-reusable parts, such as the gaskets? I'd sure like to replace with copper gaskets if possible. Anyone know?
Before you have something custom made, at least look at the OEM gaskets at the dealer. They almost all stock them, and I think you will agree that they are of very high quality metal, and only $35. In fact, Doug Thorley said to just reuse them.I would contact Cometic in Ohio and see if they have anything or if they would be willing to make something up for the 2UZ crowd.
If there is enough interest, Cometic will make you anything that is gasket material.
They do the oversize HG's for 1FZ's for folks going .1 over or adding SC or turbo.
I'm 3/4 of the way done with a DIY. PS is replaced. DS header nuts are off, but one of the collector bolts is frozen and I've sheared all of my 3/8" extensions. Taking a break, going for a run, then up to Sears. Will post a DIY pictorial when she's done. I'm pumped!
We're on the same page today! I also have the PS header mounted and ready to start the DS. But what did you do about the O2 sensor wire being too short on the passenger side (DT repositioned the O2 sensor port on the header...)? I can certainly lengthen the wires but don't remember anyone mentioning this issue.
Ya, what a bugger that was! The wire toward the front has a lot of slack if you remove it from the forward engine clip and the clip where it turns vertical. Once you remove it from those two it has plenty of slack and you can zip tie it to the pipes running along the frame. At the front of the engine, just re-clip the bundle into the open clip.
How were your header nuts? Mine were easy. It's the collector bolts that are a mother bear!
I ended up removing the steering shaft to help with the driver's side along with jacking the engine up about an inch. If you remove the two engine mount bolts, you can jack the engine from below. I made a hillbilly block which fits up at the back of the pan and is held up by a 2nd floor jack.
The other fun part was getting access to the nuts on the new PS header! The only thing that I could use on a couple of them was a 14mm box/open. It's much tighter with the new header!
Have fun! I may be done for the night as the pregnant wife is in need of some 'quality time', so I'll probably finish after church tomorrow.
Thanks...I hadn't traced the wiring for slack! The nuts were rusted but all studs just backed out with my 3/8" impact gun. I have enough studs to replace all. Yes the tubes on the DT headers do require a number of wrenches (14mm ratcheting stubby, angle ratchet, straight ratchet, crows foot, swivels and a myriad of extensions) to get in there. And even at that there are a couple I'd like to get just a smidgen tighter but the limited space limits wrench leverage...
Although not impossible the DT's definitely will take alot more time to replace an O2 sensor. All in all the PS was relatively easy and straightforward. Not expecting that on the DS
Better be worth it!
I used a 1/2" impact with about a 20" extender with various flex impact sockets and/or regular flex joint mostly accessed from underneath. And for the tighter nuts I used 3/8" impact with extender bars. For those two tough to access nuts on the PS DT I had to use four different spanner ratchet wrenches (stubby, flex regular, off-set and straight) to get them on and tightened.
I inserted the PS header, probably like you did, from the rear side...flexed the CAT pipe out of the way for clearance. All in all it only took me about 2-hours to complete and I was happy with that especially considering it was the first time.
But I'm not looking forward to those front side driver's side nutstomorrow.
What I saved in labor by doing it myself I used for new tools I've previously not needed. Oh well.
FYI: I called my local shop that does my A/C and alignment work for a back-up plan just in case this job went ugly south. They quoted a combined 16.5 hours to both sides![]()
. Whatever rate book they used must have included pulling the engine
You'll do fine as long as you don't snap a stud. I bet you were pleasantly surprised when they backed out of the block rather than snapping.
The trick on the DS is pulling the steering shaft. Makes a world of difference. Two 12mm bolts on the top and one on the bottom. You need to pull the front skid plate to get to the bottom shaft clamp, but it's an easy removal. Once loose, slide it up toward the firewall to get it off the rack, then back forward to slide it off the column.
Yes! Fortunately I just replaced, earlier this year, the steering shafts, bolts and nuts apart of the steering rack R&R so it should come out without any rust related issues.
Ditto on the reasons for working on my/our own junk!![]()
