I'm starting this thread to collect as much info in one spot about this device.
I kindly ask that people who haven't had first hand experience post questions in the various other GROM VLine related threads.
That way we can just collect first hand experience which will be a good resource for current and future users of this device.
This won't be installation heavy as there are great threads that already cover that.
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
One poster said it perfectly that this device is so close to being perfect it is even more frustrating when there are problems.
But maybe we can share what we've done to manage it
One reason I am sticking to this unit is they seem to be responsive and constantly updating and improving the product so I don't feel like I am stuck with a static product that may or may not have flaws.
I ordered the VL2 in the last group buy
2017 LC200
Installation was easy
I tested unit with the 16 pin in and out and didn't notice a difference so left mine plugged in.
Although some people have said they can't hear me well when I take a call thru CP so I might mess around with the mic gain and maybe the 16 pin disconnect
I will say so far my experience with customer service has been great and terrible too.
Response time is great and they will get back to you in a few days.
But I clearly had a lemon the first time I installed my VL2 and there were multiple issues. Getting them to just replace the unit took a bit of escalation of the frustration but the replacement unit
seems to be working better. I will list my problems and the workarounds I've found some success with
1) horizontal flickering line
This happens when you update to the latest FIRMware LEX7TK (Aug 2021)...dates are when I updated not necessarily the release date
The flickering line is at the bottom of the screen
I hounded them to give me a copy of the older Firmware so I can roll it back
They finally relented and I put it on a usb and plugged it in and the problem goes away.
Per GROM they are working on this and collecting data on the parameters of all the different screen sizes so they are aware
2) restarts
so I get 2 different restarts occasionally
First type the screen flips to the OEM nav screen and and the audio has an annoying buzz. Then 3-5 seconds later it flips right back to GROM/CarPlay as if nothing happened
Second type is OEM nav screen + buzzing and then goes into full restart. It flips to VLine splash screen and reboots.
These also come in different flavors. Sometimes the CP connects after 15-30 seconds and it's good to go
Other times it has trouble reconnecting to CP and I'm stuck in the GROM screen (see below)
A new one is that I get a splash screen that the Bluetooth has stopped working and then I'm stuck in that loop
I was thinking that it might be related to my iPhone losing signal as it seemed to happen in a cellular dead spot near my home more often then not.
Also seemed to happen when I pass by our local PD helicopter pad. But now I'm thinking it is random and not based on location.
I used to get a "DASH LINQ isn't responding" error message but I think the updates have fixed that
I still have a iPhone XS Max which is getting a teeny bit glitchy so not sure if it is phone related
Will be updating phone this next cycle so we'll see.
I disconnected my Iphone from the OEM LC system completely but that doesn't seem to matter
Also I have consistently updated them on this so they are aware.
If you have an issue you can connect your unit to the internet and then hit the buttons on your steering wheel in this sequence
">>>>...<" so forward forward forward forward back (edited)
And a small popup will show on the bottom saying logs are being prepared and sent
This seems to be helpful for them to try to figure out what the problem are originating from
3) trouble reconnecting to CP
Sometimes this is upon initial ignition start up of the vehicle. But updating to the latest V2OVL3.44.0.0 (Aug 2021) update seems to have improved that alot. CP starts up super quick
With the above mentioned restarts issues...if it reboots and I don't re-establish CP connection...this does seem to affect initial ignition car startup connection too.
If I had a random restart and CP connects smoothly. When I turn the car off and back on, it seems to have a more consistent CP launch
But I have noticed that after a random restart the GROM unit Wifi is on and that seems to prevent CP from connecting via BT and then via it's local VLINE Wifi. This is all speculation on my part.
So I will go into the Wifi setting for the GROM unit and turn it off and then CP seems to connect more smoothly.
When that doesn't work I try to manually connect to my iPhone via bluetooth and that sometimes helps
And when all else fails I just go to the VLine update page and reboot and sometime that seems to help
Why am I sticking with it despite all these issues?
When it works it's GREAT.
I think the company is committed to ironing out all these issues the best they can.
I like the idea of Wireless CarPlay but as I am in the midst of rewiring my car with the ARB Linx and Compressor etc... I may set it up so it can just be a wired setup and that could get rid of some of the glitchiness
I am hoping I could do some integration with ARB Linx and this unit but so far no dice
In speaking with the company they have planned upgrades in the future like OS updates and the unit has an HDMI out that may come into play for future versions so they are forward looking
I don't mind tinkering
Hopefully some of the other users can chime in with their experiences and solutions.
I will also update GROM with a link to this thread so they can maybe see LC200 related problems all grouped into one spot.
Grom VLine
GROM VLine - Google apps/Android&iPhone integration
Grom Vline.. yay or nay?
Grom vs EC offroad vs Naviplus
2017 LC200
2) restarts
