I use Redline CV joint grease in Birfields/CV joints, steering bearings, wheel bearings and am considering using it in U-joints. A CV joint, as used on a front driver, is the worst case scenario for a grease. Lots of load, lots of heat, lots of relative speed between parts. A grease the lives there will work anywhere. Among other things, these greases tend to have a high moly content.
I was put onto using CV Joint grease in wheel bearings by a guy who does Cup car fab & prep. He said prior to Krytox grease that CV Joint grease was the only grease that would live through a 500 mile race in the RF outer wheel bearing. By the rules those are a tiny bearing and getting one to live a full 500 race is a trick.
My experiment in using marine wheel bearing grease produced dismal results and very short bearing life. I've never known if it was because of it being Sta-Lube grease (as a brand it's not high quality stuff) or if the grease was simply not up to the task.
The only grease that won't have some chemical effect on urethane is silicone grease. Energy Suspension sells it. MAF says their bushings aren't effected by petroleum based greases, so we'll see.
