Got the tac working! but not really..... (1 Viewer)
Tacoma, WA
We got the fuel pump sensor wired to the gauge but it seems the "ratio" or calibration is off. When i start the engin the needle begins to fluctuate a little but remains at zero. The needle moves when i rev, but where I should probably be at around 2500rpm the tac reads under 500rpm.
I guess this is because the old sensor was on the bell housing and the new one is one the pump so the guage it calibrated for the bell housing unit?
I figure i will need a new tac and would like to keep in in teh stock location if i might. SO..
- does a BJ60 tac run off the fuel pump or the bell housing? possible swap?
- I would imagine a 70 series tach would not fit in the 60 series location...am i wrong?
- What aftermarket options do i have?? Most aftermarket tacs are distributor or coil actuated...no?
In the one HDJ60 swap I've seen, a HZJ7_ tach was modified to fit into the 60 instrument cluster. I've also read of how a guy in Oz took his HJ60 tach to a shop where they redid the electronics of the tach.
Talk to some speedometer shops and see what they recommend. Maybe ask these guys: http://www.terf.com/TachChangerPage.htm
Some aftermarket choices:
http://www.tinytach.com/tinytach/diesel.php
http://hp.autometer.com/instructions/002888_instruction.pdf
Dave
