Couple of things I can throw in to the mix here. The pintle hitch can be bought as a flat plate design, then an adjustable mount for it to bolt to. Stay away from the ball one's though...too much noise back there on the trail.
Okay, so having had a Canadian version of this trailer for some time now, I can say they are "neat" but not a great trailer out of the gate. To really be useful, it needs to have a tail gate in it or at least a dump feature for hauling landscape stuff. I made a gate for mine and I don't regret it at all. I also put a fold up wheel on the front for moving it around and that makes it much nicer because the boogers are HEAVY.
You can put a tremendous amount of weight in the CND versions, but I don't know about the us version. These trailers are HEAVY even unloaded. My v6 exploder knew it was there and my 40 does too. It's not too bad once up to speed, but you will feel it on hills. Off road, they bounce like the dickens....the springs are just so stiff. Maybe you can change shocks or remove a spring leaf to make it better. You would need to really have the trailer full to keep it tracking smooth back there otherwise.
Backing up on the trail is a PITA. Scary really....I don't like doing it at all. It's difficult to back one of these on pavement because they are so short. The good thing is that they track very close to the truck, so if the truck makes a turn, it's likely the trailer will find the path too. (Read: no real reason to swing wide on turns) Some people have retrofitted an extendable tongue, which I have considered doing as well.
R
