Yes, and for that, I would fuse it to blow before the wire melts.
I.e if the wire is good for 40 amps, fuse it at 35. The wire will never need to be serviced due to melt, and there should he a handy pack of 35 amp fuses in the glove box to prevent a stranded situation. With a fusible link wire, you're at risk of burning it out completely and being stranded unless you can make that connection on a whim.
As far as I know, a "maxi fuse" is slow blow fuse. Theyre about 4x the size of a traditional automotive fuse. But now you need to run wire big enough to not melt at the slow blow fuses over rated slow blow. At that point, you may as well run what the circuit is rated for. If it fails, you likely went direct to ground. At that point, other corrective action is required so the fuse doesnt blow again. I.e failed component going direct to ground constantly blowing fuses. IMO its unaccaptable to put a slow blow on something. It either failed, or it didnt. I dont want a slow blow 10gauge wire carrying more current than it can handle every other time for a short period of time. That is guaranteed to fail long term.
If the underhood fuse box feeds 80 amps worth of stuff with everything on, feed the box with 90 amp capable wire direct off the battery with a 80 amp fuse. Your supply wire is protected, and the 80 amp fuse is the serviceable component. If things start blowing individual fuses after the fuse box, you have an issue within that standalone circuit.
Bottom line, if youre going to fuse it, the fuse MUST be rated less than the wire, otherwise the wire is the serviceable component.
