DFXR
Well, whatever you did, congrats for getting it to pass the old-fashioned way.
Thanks man! I'll be ready for my next one.Well, whatever you did, congrats for getting it to pass the old-fashioned way.
So, @Gadjeep , you adjusted the idle mixture screw in order to get the correct AFR at idle, but doesn't the Kalifornia smog test also take measurements at one or two addition RPM settings?
If that is the case, I can see using smaller diameter main jets (primary main at least...and secondary main only if the test is at WOT) as another factor that one can change in order to improve the likelihood of passing...
Those are some clean numbers. You can see how fixing your AI brought the residual O2 up. Lots of CA smog threads here over the years seem to end with AI system fixes.
My recent CA tests have had a 15 mph test as well as a NOX measurement, wonder why yours didn't?
So after all this work you did you are going to sell the 60? NNNNNOOOOOOOOOOOOOOOOOO!!!!!!!![]()
