GEOLANDAR X-AT on 100 series (1 Viewer)
'04's have 18" OEM wheels? IDK that.
My '05 did. I could be wrong here but I'd assume any 03-05/03+ wheels would have been consistent.
In any case, OP gave tire sizes he was looking at. The 18" tire will fit the 18" wheel.
I called Yomama (Yokohama) and the CSR said it would not fit it..I asked why and she said that doesn't say it would fit in the database she had...I should have known better than to trust a phone rep..thanks all for the clarification!
They fit, I have the 275/75R18 (33" diameter) on Tundra Rims. I do have spacers but mainly to run the Tundra Rims.
got them put on yesterday...those tires are STIFF. It's going to be interesting off-road compared to what I had on there before. Thanks all for the help!
I had these for 4 days and promptly returned them. Went back to Nittos, this was just last week. They are noisy! they do look good tho!
You take the air out off road. They'll feel like clouds then.
I need a lift/levelling kit if anyone has a recommendation..I drive it daily but get off into some interesting places when hunting/fishing. I am not trying to crawl over Mt. Rushmore lol
You can likely get away with a set of light to medium rear springs and cranking on the torsion bars. A diff drop wouldn't be a bad idea, depending on how high you want to go. Front hub to fender measurements should run in the 21-22" range to keep the truck from driving funny. Rear is usually about an inch taller.
Plus you'll gain inches (in your pants) when you remove those running boards ;)
I will get to work on that post haste..Ive been ignoring a lot of things with this vehicle, and I need to remove those.
You should meet Russian Alex and Crossfit Zack. I think Zack is on here, not sure about Alex. @BurnsCrew I believe they're both near you.
