Gearstick retainer sub assembly compatability
Australia
Hello all,
I've been lucky enough to break the gearstick retainer sub assembly and it seems the exact part is discontinued (pn# 33506-60041). However the part # 33506-60040 is in stock. Would anyone know if this piece would be compatible with my car, I have a 1993 hzj80r.
Appreciate any info and thoughts.
Cheers
Solution
Just to update I finally got this fixed! I used the part from a 79 series model with the part number 33506-60180. All works well on my Hzj80 h150. If gear selection is getting rough remember to check the rubber bushing at the bottom of the gear stick
So turns out that I can't get either of those part numbers for the gear stick retainer. Would anyone know if the part number 33506-60180 that is from a vdj79 with a h150f gearbox fit to the top of my gearbox and fit my 80 series gear stick back in. All I can see is that the 79 series gearstick doesn't have a conical spring. Thanks for any help.
Solution
