Gear oil change
Wyoming MI
So I went under my truck today to change the driveline fluids. Only to be stopped dead in my tracks by the front diff fill plug.
It wouldn't budge and I didn't want to round it over so I stopped.
So my question is, what thread pitch is the plug? Is there an alternate plug that is a hex head or a square drive?
I can't answer your actual question, but can you get a torch on it for a minute?
Can't answer your question, but make sure you use the correct size metric wrench. Wrench should be very snug with 0 wiggly room, and push all the way into clean hole. Then use leverage if you must. They can be very tight.
I use the two hammer method lol. Place a brass hammer against the fill and take another hammer and wack the brass one. Now it should come off with your 10mm hex. Works every time. You can possibly use a regular hammer if you dont have a brass one handy.
What? An excuse to go buy another tool? Say it ain't so!!
Thank you. I will look into that. I did not strip it out, I used a 10mm hex head socket and using a 16oz persuasion tool on the handle of my ratchet I stopped before any real damage was done.
I don't have a brass hammer. I have many hammers, just not brass.
I found the specs for the plugs. So now I can search locally for alternatives.
TOYOTA/LEXUS NISSAN/ INFINITI
Did you use a 10mm hex socket? SAE will ruin it.
The factory 10mm allen are much less prone to stripping than 24mm bolts. Probably the reason Mr T did away with the 24mm plugs years ago and many owners upgrade to the 10mm allens. :doh:With the difficultly getting to the front plugs I would caution anyone changing to something else.
Try a 15/16" socket on the 24mm plug...perfect fit and just a bit more snug on the plug.
Steve
I had our mechanic at work break loose the fill plug. So this weekend I'm going to give it another go.
