I thought I'd post up some pictures of the gauges I installed in my Cruiser. I made a really simple fiberglass piece and then covered it in grey vinyl. The gauges are from GlowShift - I really like the digital readout, as it takes the guess work out of reading an analog gauge.
I'm currently running a tranmission temperature gauge and a water temperature gauge. I'm already thinking of making a slightly different form for the console, and adding an oil pressure and oil temperature to the mix. These gauges are nice in that they're only 1" deep. I think if I push the panel back to the level of the power outlet I added, I could fit four gauges across it.
Here's the pictures, starting with making the bracket:
And a couple installed pictures:
I drilled & tapped the boss in the transmission just above the transfer case flange of the front driveshaft for the transmission temperature sending unit. This was a bit tricky, requiring the removal of the front driveshaft and the use of a right angle drill to make the hole. Short drill bits are helpful here.
There is also a boss in a water neck just between the distributor and the intake manifold for the cooling system. I drilled & tapped this for the water temperature sending unit. Problem is, this is on the 'cool' side of the system - it's the coolant that has passed through the radiator and is as cool as possible. Around town, my temps for this location are showing in the upper 160 degree range. I think I may drill and tap the thermostat housing tomorrow to get a more accurate reading of the temperature coming out of the engine.
For the record, after some driving around town a bit, my tranmission temperature is only showing in the 150 degree range. I'll put this to the test later this week as I haul a pop-up from Denver across the continental divide to Ouray and back again.
