Parting Out [GA] FJ40 PART OUT
paki bows for 700 please... also my be interested in other bits and pieces as you post them up. also I can likely pic the stuff as were going through atl in about 6 weeks.
Hi...I am looking for a floor grommet around parking brake cable..It is made out of metal and rubber I think...I is elips shaped ,does have 2 holes for bolts on each side to be secured to the floor...Do you have that part in 76?
That's not it-is this part on the parking brake cable on 76?My part is basically rubber grommet(might look like a bubble) with metal outside...this grommet is wraped around park.brake cable just where the cable is passing through the floor...is has 2 holes.you bolt is to the floor to make nice seal around the cable...Mine 40 is 77 so I don't know if 76 has it different...Please let me know..Thanks Mike
Do you need the gasket too?
that's the part :-) ...what you want for grommet,gasket around grommet,2 bolts holding it to the floor and if brake cable is good what you want for it?Is a brake cable ok near TC area?Mine is burned there.I thought you sold the pro-90 seats already...are they in good shape with brackets included?is Horn relay OK?Do you have hazard switch?Let me know on my email...drnek@centrum.cz....Thanks Mike
looking for the two clampy bracket pieces that attach the air cleaner intake hose to the intake horn located next to the radiator and the drivers side fender.
and i would be interested in just the metric tlc spare tire extension piece.
Do you have any of the wiring harness? I need the roughly 2 foot section that goes from the main wiring harness under the dash to the wiper motor. Looks like the one in the pic below.
