TCSTARK
Master Debater & Cunning Linguist
- Location
- United States
As always, if you see something you want make me a reasonable offer and we will make a deal.
Quick Reference Update
Radiator Support Frame - $10
Wiper Motors - Top $25 as-is
Switches - $3 per
Dash Knob Brackets - $5
Early Heater Vent - $10
Emergency brake assembly - $8
License plate mount bracket - free
Seat bracket mounts - $5 each
Misc tailgate bracket clasp -$5
Quick Reference Update Stash #2
Fuel Inlet Cover - $10
Early Door Cranks - $5 per
Early Choke Cable - $35
Fuel Inlet Cover #2 - $10
Misc Liftgate Struts - $20
Early Hazzard Unit - $15
Misc bracket/Heat shield - $5 per
Misc brackets/grommet - $2 per
Upper/Lower Thermostat Housing - $40 both
NOS Fuel Filter - $15
Misc Steering Arm nut/ clamps - $20 all
SOR front engine mounts - $25 all
Wing Window Weatherstripping - $30
Ignition Switch Housing - $15
Drivrshaft Bolts - $7
Misc Brackets/Covers - $5 piece (brake line brackets sold)
Hard Top Gussets - $20
Misc Brackets - $5 all
Steering Column Bracket - $10
Alt Bracket - $5
Turn Signal Protectors - $25
Koyo U Joint - $15
Quick Reference Update Stash #3
73 Gas Tank - $25
Stock clutch and newer pressure plate - $25
Throw out bearing - $15
Drive shaft flanges - $20 pair
Rear drive shaft - $25
Exhaust manifold - $35
FJ60 upper/lower manifold - $50
Oil pan - $40
Drum backing plates - $10 each
Front Hub Assemblies - $20 each
4 sp Clutch inspection cover w/o motor mounts $20
Early Door Bottoms- $50 Pair
Early Drivers Door - $75
Early stock steering arms - $20 pair
Switches - $3 per
Alt Bracket - $5
Koyo U Joint - $15
73 Gas Tank - $25
Oil pan - $40
