For Sale {GA} 1989 FJ62 “Showroom Original Condition” 96,349 miles
**** SOLD **** SOLD ****
Headed to California
1989 TOYOTA LAND CRUISER FJ62
One Owner 96,349 miles
To advertise a 22 year old vehicle in Showroom Condition you have a lot to live up to. Add to that one owner with original paint. Now the questions really come like how could that be. This Land Cruiser has belonged to a good friend of mine since new. Health problems and a change in location force this sale. He is a retired airline mechanic who keeps a log book on his vehicle just like airplanes require. Every oil change, brake job, tire rotation, even washing and waxing is documented with the date, mileage, and part invoice in his log book. As an example: oil, filter, grease fittings all serviced and changed every 2,000 miles. Now let’s inspect the interior. A behind has never touched the seat and a shoe never has touched the carpet. Towels and covers protected them to keep everything in like new condition. A deflecta-shield on the front ensured no bug or rock chips. You will not find a scratch, door ding, rock chip, fade, stain, or dust ball in or outside of this vehicle. The yellow cadium bolts and hardware shine like new under the hood and in door jams. The original paint is in remarkable condition and shines like new. In 1991 it had a touch-up to the left front fender and rear tail gate. No evidence of this can be seen on the vehicle.
Special ordered through Evans Toyota in Forest Park, Georgia. All options available were ordered on this Land Cruiser. Several options not available were added: cruise control, auto dimming rearview mirror, halogen bulbs, dash cover, and hitch brake light. JVC am/fm/cd added without any modifications to the dash. Original Stereo available and can be re-installed upon request.
As listed above the maintenance on this vehicle is remarkable. I have the item, date, and mileage performed below.
Oil and filter change 12-89 2,475
Wax and clean 2-90 3,790
Oil and filter change 3-90 4,282
Oil and filter change 6-90 6,230
Wax and clean 7-90 6,355
Add deflecta-shield 8-90 6,812
Rotate all tires including spare 8-90 7,083
Oil and filter change 12-90 8,352
Oil and filter change 4-91 10,139
Trailer hitch install 6-91 10,184
Clean engine and underside 6-91 10,191
Adjust and check valves 6-91 10,191
Oil and filter change 9-91 12,080
Gasket and new oil drain plug 9-91 12,080
Rotate all tires including spare 11-91 13,020
Balance (4) tires 12-91 13,552
Oil and filter change 1-92 14,551
Oil and filter change 4-92 15,643
Oil and filter change 8-92 16,993
Gasket and new oil drain plug 8-92 16,993
Anti-freeze changed 9-92 17,726
Rotate and balance tires 12-92 19,133
Oil and filter change 12-92 19,183
Slick 50 engine formula added 12-92 19,183
Gear oil change 1-93 20,254
(transmission, transfer case,
front and rear differentials)
Slick 50 added front and rear 1-93 20,254
differential and transfer case
Change transmission fluid 1-93 20,319
Slick 50 added transmission 1-93 20,319
Oil and filter change 5-93 22,142
Replaced relay rods, tie rod ends, tubes 6-93 23,187
Align front end 6-93 23,203
Oil and filter change 8-93 24,480
Oil and filter change 12-93 27,543
Repack front wheel bearings 12-93 27,543
Turn front rotors 12-93 27,543
Adjust valves 12-93 27,543
Replace air cleaner 12-93 27,543
Replace spark plugs and pvc valve 12-93 27,701
Replace fuel filter 12-93 27,701
Rotate all tires 4-94 29,410
Oil and filter change 4-94 29,410
Oil and filter change 6-94 33,260
Wax car 6-94 33,260
Oil and filter change 9-94 34,970
Wiper blades changed 12-94 36,762
Oil and filter change 12-94 37,511
Oil and filter change 4-95 41,136
Wax car 5-95 41,505
Oil and filter change 9-95 43,409
Rear brake drums and shoes cleaned 12-95 43,409
Oil and filter change 12-95 44,909
Battery replaced 12-95 44,527
Oil and filter change 5-96 47,571
Check front brake pads 5-96 47,571
Oil and filter change 10-96 51,653
Flush cooling and new anti-freeze 12-96 52,983
Clean engine and underside 12-96 52,983
Wax and armor-all 12-96 52,983
Oil and filter change 5-97 54,613
Gear oil change front and rear differentials-97 55,050
Slick 50 added front and rear differentials 7-97 55.050
Radiator boil and repair 8-97 55,295
New radiator cap 8-97 55,295
New belts all 8-97 55,325
Transmission and transfer case changed 8-97 55,463
Slick 50 added trans and transfer case 8-97 55,463
Rebuild brake master cylinder 8-97 55,463
Oil and filter change 12-97 56,948
Slick 50 added to engine 12-97 56,948
Clean engine and under side 12-97 57,041
Clean and wax car 12-97 57,041
Turn rear drums and adjust brakes 12-97 57,083
Install new rear brake shoes 11-97 57,331
Turn rear brake drums 2nd time 1-98 57,762
Replace air filter, fuel filter, spark plugs 2-98 58,263
Repack front wheel bearings and seals 2-98 58,301
Turn front rotors 2-98 58,301
Bleed brakes complete 2-98 58,301
Oil and filter change 4-98 60,498
Oil and filter change 9-98 64,912
Repair Radiator 9-98 65,562
New rear drums and shoes 12-98 67,992
Oil and filter change 1-99 69,016
Wash and wax car 2-99 69,667
Wiper blades front and rear replaced 3-99 70,105
Oil and filter change 6-99 71,443
Slick 50 added to engine 6-99 71.433
Service a/c system 6-99 71,578
New radiator and thermostat 9-99 72,596
Clean engine and under side 12-99 74,056
Oil and filter change 12-99 74,056
Waxed and cleaned interior 12-99 74,131
Oil and filter change 4-00 75,434
Battery replaced 8-00 76,110
Battery replaced 12-00 77,049
Oil and filter change 12-00 77,150
Oil and filter change 5-00 78,717
Gear oil change 6-01 78,969
Slick 50 added front and rear 6-01 78,969
differential trans and transfer case
Change transmission fluid 6-01 78,969
Slick 50 added transmission 6-01 78,969
Oil and filter change 12-01 80,727
Clean, wax, armor-all, engine, under side 12-01 80,727
Replace alternator 1-02 80,832
Oil and filter change 6-02 81,792
Fuel filter and air filter replaced 10-02 82,535
Oil and filter change 10-02 82,535
Re-core radiator 10-02 82,535
Flush cooling system, new anti-freeze 10-02 82,535
Oil and filter change 4-03 83,303
Wiper blades changed front and rear 9-03 83,821
Oil and filter change 11-03 84,004
Change transmission fluid 3-03 84,662
Slick 50 added to transmission 3-03 84,662
Flushed brake system 10-04 85,307
Sylvania white star head lamps 10-04 85,307
Oil and filter change 12-04 85,753
Complete clean and wax 10-05 87,307
Oil and filter change 5-05 86,123
Oil and filter change 12-05 87,479
Halogen back up lights installed 2-06 87,674
L & R marker lights 10-06 88,746
Transmission fluid changed 11-06 88,907
Oil and filter change 11-06 88,907
All leaf springs lubed 11-06 88,907
Spark plugs 2-07 89,468
Wiper blades changed front and rear 5-07 90,022
New shift lever bushings 8-08 91,861
Changed transmission fluid 10-08 92,161
Oil and filter change 11-08 92,217
Gear oil change 11-08 92,217
New anti-freeze 3-09 92,754
Spark plugs, distributor cap, rotor 10-09 93,618
Located just outside of Atlanta in Newnan, Georgia 770-463-5578
To see 92 pictures type in the following web site:
http://www.fototime.com/inv/DD72FAF5009D5F7
Beautiful Cruiser....I wish that original window sticker said 22 city
and 24 highway instead of 12/14.:)
Good luck with the sell .........1978HJ45
WOW. Had to wipe the drool off! Very nice truck!
Wow. very nice - good luck with the sale
Need a cig, after admiring that.
Very nice!!
Would love to have another cruiser, but not good time for it.
Good Luck
Yeah Buddy! NICE rig!
