FZJ80 headlight Lens Removal How To? (5 Viewers)
I received my new junk yard headlight today but the lens appears to be glued to the plastic assembly. Yes, I have removed all the clamps and top and bottom metal plate. Does anyone know how to remove?
Oven
Ok.. after heating and removing what do I use to stick it to the correct plastic assembly?
crikeymike
Exit Offroad - Dobinsons Specialist
Supporting Vendor
Jacksonville, Florida
I think people have said before to heat up the parts again, and reattach them and it will glue itself back together.
Melt Down
OK. So now I know that the plastic casing will start to melt after 10 minutes.
Arizona
If you are starting with the piece with the good glass first this is a good thing since all oven times/temps vary. I am hoping that is the route you took.
Also do a search because I think lndcruz or someone else shows this step by step process using Depo headlights. It would be the same process just using the OEM instead.
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
