Hello from Hungary
This is my first post I hope you find it interesting and I am desperate to get help with this issue
I am going to twist your minds here
Ive been reading posts from this site in the past 5 years since I own my 80
This is a very informative site and it helped me a lot to keep my cruiser in shape
I have a very strange problem that nobody can solve with this car in the past 2 years, I hope you could shed a light on the possible fault(s)
The car:
1997 FZJ 80 4500i, automatic A442F, OBDI (UK model RHD)
Yes that is 1997, only 1 oxygen sensor, no temp sensor @ EGR on inlet manifold, OBDI
The symptoms are:
- Lack of power (I am guessing that 30% of the power is missing) BAD
- High fuel consumption (I know these are thirsty but the average was 15l/100km, now 20l)
- Spark plugs are white, like you dip them in ash
- ECT sensor reads 95C degree @ idle, goes as high as 120C uphill (I have TOYOBDI android)
- Idle is not as smooth like you can place a coin on the edge on engine anymore
- NO fault codes in ECU at all
- I look as grumpy as Walther Matthau driving it coz it is not running right
Things that I replaced/renewed/fiddled with/cried over them:
- Ignition (Spark plugs 4 different makes, coil, leads 2 different makes, rotor arm and cap)
- Fuel filter
- Injectors cleaned, serviced, tested
- MAF replaced with 2nd hand and another from a known good running car
- TPS replaced with one from a known good running car
- IAC motor replaced with one from a known good running car
- Throttle body removed and cleaned
- Engine compression checked and all between 175-180psi
- EGR system removed, cleaned, inspected, modulator replaced with new blue sticker one (I also tried plugging the EGR since it gives no fault codes if you do it on this model as it does not have the sensor to tell the ECU you tampered with this)
- Engine wiring harness checked and I even replaced with an other harness to be sure it is right (this is RHD so the harness is routed away from the EGR pipe so this is not suffering from the melted wire syndrome)
- Engine ECU replaced just to be sure (1997 shouldt suffer from ECU fault but replaced anyways)
- All vacuum lines replaced everywhere
- All gaskets replaced on exhaust, inlet manifold
- PCV, grommet, hose replaced
- Checked manifold for cracks with cold start spray everywhere and visually when it was apart
- Intake rubber pipe replaced from MAF to throttle body
- Ignition timing checked in service mode, Ive played with it a lot, no change
- Cat converter checked deemed to be ok but replaced with a straight pipe just in case, no difference(it only has 1 oxygen sensor from factory before the cat so no matter if you remove them)
- Air filter of course replaced
- Radiator, hoses, thermostat, water pump replaced
- Knock sensors, both replaced
- Engine temperature sensor replaced (the old one tested ok for resistance but just in case)
- Alternator serviced with new brushes and bearings
- My credit card limit
- A divorce (we reunited)
Am I missing anything??
Please give me an idea, anything that you could think of, this car is driving me crazy, after all that Ive done it is still not right
Thank you
The car:
The symptoms are:
- Fuel filter
Thank you
