I have been trying to pinpoint the source of a very light "clicking" noise that has been emitting from the left side of my LC. The noise is probably best described as a light click, almost a light ratcheting, sound that is only on the left side of the truck. I only hear it when the left window is down, and the noise is more prominent when driving next to objects such as curbs, cars, walls, etc. The noise appeared to be coming from the center of the vehicle, so I was suspecting an issue with the rear shaft/u-joints or transfer case.
In order to play the process of elimination game, I removed the rear drive shaft and drove the LC around the neighborhood in FWD mode (CDL locked), and the noise was gone. So based on this test, I figured the source of the noise was in the drive shaft. I checked the drive shaft for any excessive play or binding in the u-joints as well as the splines, but they felt perfect. The drive shaft was greased up and re-installed. Greasing didn't help rid the noise.
The other day, I had my buddy drive the truck in a parking lot while I walked/jogged next to it in an attempt to find the location of the noise. The noise is definitely coming from the left side only, at both front and rear wheels. I was originally thinking that it's time to lube everything up (CV's, bearings, bushings), but the part that confused the hell out of us is when the noise went away when I poured a bottle of water to wet the pavement.
I have BFG AT's with tons of meat on them... could the clicking noise be coming from the tread/pavement contact?? Why only on the left side? The AT's are not directional.
I'm confused.
I'm confused.
