Fun swap for the ambitious N04C-T
bjowett
Supporting Vendor
North Adams, Massachusetts
This popped up on eBay, located in Tennessee, $4500 shipped, include transmission. This is a 4.0l 16V N04CT (modern W04CT) with what should be an A860e 6 speed automatic. Best guess... This also should be 24V and 177hp/354tq. 3200 RPM redline. The transmission has a 3.3 1st gear and a nice .58 OD in 6th. Despite having the harness and ECUs, the electronics could be quite the challenge, not mention adapting a t-case.
Factory manual for the N04CT w/ manual trans is all I have....
This engine is fitted to 4wd versions of the Dutro, but the rear drive shaft exits from the centre of the t/case. So you could probably use the t/case but you would have to use a centred diff with it.
Lol (at myself)... the 15BFT is still in process. W04CT is sitting upstairs in the barn.
It's only comical to me because I do the same thing. I have three 12hts and three 3bs in various stages of disrepair right now and it's still hard for me to pass up a "deal".
I've been eyeing those up too! I think one of the 15bfte/dyna manuals I posted covers the n04ct in some detail also. These motors were used in the late model mega cruisers too I think? So shouldnt be too strange, as probably connected to same drivetrain as the 15bftes did.
Hello
I am not a mechanic at all
What could be the challenges in swapping my old 2H engine for a Hino N04C in my HJ47 engine bay (while keeping my original H55F 5-speed gearbox/transmission)?
Mostly this^
-Fabrication of adapter plate between engine and transmission
-Adding the whole electronic control systems for the engine
-Relocating engine mounts, transmission crossmember
-Connecting up all other parts of the engine, all the pipework (e.g. exhaust and intake are on opposite sides on the N04C vs the 2H).
-I would expect the sump pan will not fit around the front axle of a Land Cruiser.
-And many more things that come up.
This would be a good challenge for an experienced mechanic/engineer.
Mostly this^
Thanks for the inputs!
I am alreading freaking out at ''Adding the whole electronic control systems for the engine'' :p:D
