Fuel pump will not shut off
Close to the Country, Hawaii
First I would like to thank bsmith123 for pointing me in the right direction, the diode fixed my engine wpouldn't shut-off problem. The fuel pump continues to run after the engine is shut-off. Again, I open to suggestions. Thanks.
glad to hear it!
glad to hear it!
on the fuel pump
I imagine it is going to the fuse box---you should have two sides one that is hot all the time and one that is hot with the ignition on--sounds like the wire might be going to the hot all the time side of the box
If you take the power wire off the pump and shoot it for power and remove the fuses one at a time you may see which fuse is powering it
unless it is wired in on the wrong side of the fuse ---then just remove the terminals one at a time until you lose power
unless you can just follow the color code of the wire
