Guess it's time to replace the fuel pump. Is aftermarket ok? (alot cheaper than OEM). If OEM, who's got the best prices from the vendors here on Mud?
Beck Arnley is usually OEM in a different box. Carter makes a great mechanical pump. After all, it's a fuel pump, not a piston, I'm sure anything domestic or Japanese will be just fine.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=NFPM70266_0199759207
Kyosan pump at NAPA. Get it there in a blue box, or at the dealer in a red one, for twice the price.
You'll need a spacer block (Advance has them for about $4, NAPA didn't have one). Toyota has the spacer block with two paper gaskets already glued to it for $11.00.
Okay here's a random queation. as forestdan7 noted, napa part m70266 is the Kyosan pump in a napa branded box. I also see that on Amazon, the carter fuel pump also references "m70266" in the description.
Any chance that the Carter pump is also a Kyosan in a Carter box?
The pictures also look identical.
http://www.amazon.com/Carter-M70266-...1&s=automotive
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Fuel-Pump-OE-Mechanical-Type-/_/R-NFPM70266_0199759309
So I rolled the dice on the Carter pump referenced above, and was pleased to find out it was a Kyosan pump(oem I think) in a carter box. Made in Japan.
