Fuel Pump By-Pass Problem with Aux. Tank
I just finished (Well Almost) installing my 18 gal. aux. fuel tank in my 60. It is a saddle tank mounted inside the frame rail and the drive shaft on the drivers side. I got the tank in AUS. I used a mechanical fuel selector valve and wired a dual switch to allow reading both tanks on the stock dash fuel gauge.
Everything mounted great and it works well except it's now overfilling the stock tank with return fuel from the fuel pump by-pass line. The by-pass allows excess fuel to return to the tank, keeps the carb from flooding and keeps the pressure on the float valve down.
The overfilling occurs when both tanks are full and I'm running on the aux tank first. I know I could run the main stock tank down part way, or even empty first, allowing room in the stock for the returned fuel from the aux tank. But I want to fix the problem so I can use either tank first. I did not plumb a second selector switch for the return line from the pump. I could do this also, more hoses and another valve = more potential issues...but I had an idea.
The manual selector valve I used is plumbed like a "T". The valve has separate "IN's" from each tank and a single supply to the pump. I was thinking of just adding a "T" in the supply line between the tank selector valve outlet and the fuel pump.
Would this work? Would it cause suction issues with pump sucking on it's own return line? I could add a second selector valve, but this would easier and only one valve to change tanks.
You input on this is greatly appreciated.
Thanks,
Thanks,
