Fuel Line Routing Help Please (1 Viewer)
I am trying to piece back together a 1972 FJ40 that I didn’t take a part and this is the first FJ I have every worked on. The ID tag says December 71 but it was tagged as a 72. I could really use some detailed pictures of where all the fuel lines, canister lines, return lines, etc. route to. I have searched the forum and found some posts that have really helped but I still am missing information. Can anyone provide more detailed pictures or is there a manual I can purchase that will illustrate what I need. Some pics of under a FJ showing how the hard lines run would also be helpful. Thanks in advance for your help.
Maybe this will give you a start. Page 168 Land Cruiser 40 & 55 Series Factory Gas Tanks
I don’t have a ‘72, or any familiarity with it.
On my ‘78:
  • The tank is under the passenger seat. The tank has three ports that connect to the evaporator
  • The evaporator or separator is behind the pillar, next to the tank. The other evaporator port has a line that runs thru the floor and to the charcoal cannister, under the hood, on the passenger side, near the heater blower.
  • The drives side of the gas tank has a feed port and a return port.
  • A soft line runs from the tank feed port thru the floor and connect to a hard line that runs, thru the OS frame rail, to the fuel filter, near the battery. The line from the fuel filter to the fuel pump is a soft line. A hard line runs from the fuel pump, up and around the front if the valve cover, to the carb.
  • A soft line runs from the tank return port, thru the floor and connects to a hard line that runs to the front, in the PS frame rail... a hard line follows the feed hard line, to the carb. The return line may connect to a third port in your fuel pump or bypass the fuel pump.
Hope this helps a bit.
Here’s where someone asked for similar
Help PLEASE HELP: Fuel line, separator, charcoal canister, hell.
On my ‘78:
On my ‘78:
Thank you!
@Kansasminers
This tip probably won’t help with your routing question.
I often use the microfiche coolerman has posted on his website. The exploded diagrams come in handy. I have it saved on my iPhone in the iBooks app so I can view it offline.
Here’s the microfiche:
http://www.globalsoftware-inc.com/coolerman/fj40/schematics/FSM Section/MicroFiche_Parts_PDF/FJ4x_FJ55_B40partsMicroFiche.pdf
Here’s his schematics: Coolerman's Electrical Schematic and FSM File Retrieval
Thank you!
