- Thread starter
- #21
That’s a good question I’d like to know as well. Also, what is FPR?
Awesome, thanks much! Haven’t paid attention to it with the holidays but I’m going to look at parts costs and see what’s worth doing. Thanks for the pics!@Rolocado I've been looking for a picture of the back of intake manifold, for one more bolt you may need to remove. I've don't recall nore can I find a picture of the non VVti manifold. But if there is one more bolt it would be around same place as on the VVT plastic intake manifold.
Here the one on the VVt for reference. It's on DS near the heater tube that is leaking.
Your pictures of small black hose circled in black, is vacuum hose for EVAP system. Under it is the throttle body, which has a very common and very small weep from a cap. This is not your coolant leak.I think I have a similar issue - leak at least the front by pass joint.
I noticed a coolant under the car which was coming down from the top - side of the engine on driver side, ac condenser, axle and ground. Also noticed coolant in the engine valley.
I got a coolant compression tester and it showed an active leak from same places and same flow.
I definitely think front water bypass joint seals are not good. However I wonder if that is it. I can’t tell if rear one is leaking or not. How can I be sure, perhaps using a mirror?
The pink spots in front of the intake manifold is something I don’t remember ever seeing it.
I just hope it is just a front bypass joint and no other major issues such as head gasket.
I just got the car and don’t know the history. I am not sure if I am going to keep it or not yet and I know once I start, I will want to take care of everything like starter, WP, TB etc.
I kind of avoid giving P/N. I give you the ability to find your own. "Teach a one to fish"Apologies for resussicating this but it may help someone in the future:
What are the part numbers for the front bypass gaskets? I have looked for a long time and come up empty... thank you!
