front turn signal bulb replacement 2015LC
On my ‘08 that I just replaced, it was in the engine bay, right behind the light. The driver side was a pain with the battery still in place but I was able to replace without taking the battery out.
Do you have to take the bumper cover off, inner fender well off?
Thanks
Nope. I just converted mine to LEDs a couple weeks ago, pretty easy, especially on the passenger side. Yeah the driver's side is tight with the battery, but I was able to do it and I have a much larger Group 34 battery in a Slee tray.
I generally always go to superbrightleds.com for auto bulbs, the bulb finder is really good. The fronts are #7443-AW60-SA, rears are #194-AHPS. You'll also need to change the flasher, get the nifty SmartTap unit, search here for how to install, it was really easy and a great addition. Really like how it added the tap-to-signal feature.
I had my shop @Chitown4x4 do my LED bulbs. They now match the LED signals in my ARB bumper in flash rate and intensity. I also ran the Smart Tap Diode Dynamics flasher relay, it’s a great mod and it prevents the fast flash when you install LEDs.
