I was out greasing the front prop shaft last month and noticed that when I pumped grease into the slip joint zerk that I saw the shaft extended outward and no grease coming of the seal.
Dropped the shaft this weekend and upon disassembly confirmed that old dried grease will block the passage of clean grease past the splines when trying to pump in fresh grease causing a hydraulic lock. I'm guessing with enough pressure one might have eventually forced this old grease out but it wasn't happening with a hand grease gun.
Once I removed the aft nuts connecting the shaft to the transfer and the front nuts connecting the shaft to the diff the shaft would not drop out. I had to remove the grease zerk fitting and compress the shaft from one end forcing grease out this hole in order to compress the shaft enough to drop in out of the truck.
