Hello All,
On my 1994 80 series, the front pinion seal had a small leak. I finally changed out the seal, however, the leak continues more so. A couple of things happened. I didn't jack up the L/C to change the seal. The FSM said the torque on the pinion nut was 145 Ft lbs. When I was torquing down on the nut, there was a snap. However,he nut was spot on at the strike point. Could I have damaged something to cause more of a leak?
The second thing, I am now thinking is the most likely issue is I didn't seat the new seal evenly. Meaning one part in further in compared to the other side. I don't know what I was thinking at the time. I should have tapped in the seal until it was even on all sides. Could this be the cause?
