Front Pads Replacement Hardware
Denver
I have a 2017 and want to confirm these are the necessary hardware parts for the front pads. I realize they may be optional but they’re cheap so might as well change out
Shims: 04945-60080
Caliper bolts: 90105-A0336
Fitting Kit: 04947-60140
Pins with hole: 90240-06024
Did I miss anything besides pads/rotos? Are these parts sold in sets or individual? Thanks for assistance!
May as well add:
4774860280 - Anti-Rattle Spring x 2
4774360280 - Pin Hold Clip x 2
I can see no need to replace the caliper bolts unless your vehicle has been located in a heavily salted area each winter.
This is in the FAQs.
I agree with this sentiment. Not sure why Toyota qualifies them replaceable. I doubt dealers have ever done it when doing brakes on a 200.
Ok thanks I thought there was one but I couldn’t find in my searches. Thanks!
I read somewhere it was a recommended replacement and since they’re cheap I thought oh well. Maybe I misread and they meant the the pad pins.
I would not put Toyota pads or rotors on mine ever again. They have warped on mine easily.
I suspect Toyota's directive that caliper bolts are single-use was related to them being safety-critical... and, not sure how wide-spread it was, but a number of people that I trust to know how to torque hardware had them loosen up on their 80-series. These are the same bolts as on the 08-15 200-series brakes.
I personally reuse them, but I do try to remember to verify torque after a few days of driving. No issues with loosening, whether the original 2013 bolts or now the 16+ hardware (which runs a much higher torque value)
Also, 100k hard miles on toyota rotors and they've never pulsed unless I was being dumb with them.. in that case re-bedding the brakes fixed the issue.
