Front Output Needle bearing
Herb
Virginia
I have a shredded needle bearing in my front output cone. See pics below...
Does anyone have this part number handy??
Thanks
Doug
John,
Thanks man!
Hey, do you know if I would be able to press out the bearing/seal on this thing myself? Or, should I just take it somewhere and have them do it.
The old cage is in a cavity on the front end of the output shaft. It's easier to remove with a puller like mine, but you can get it out with various tools, etc. You can try to cut it out with side cutters, whatever, like we did to your rear axle bearings. Installation is just with a socket and tap it in gently. Wouldn't hurt to add oil to the outside of the bearing cage to help tap it in.
Thanks Dan....I'll just start trying different things to get it out.
