in building up my fj40, i have installed a 350 v8 with a th350 auto transmission. i used the downey 'short' adapter to connect the transfer case to the transmission. in doing so, the front output of the transfer case interferes with the transmission oil pan.
i got the smaller output flange, and with some persuasion (denting) of the oil pan, got it to fit (barely). however, with my 4" SUA lift, the smaller flange does not have enough 'angle' to work (i dont know how to describe other than the joint binds up before the driveshaft can drop far enough down to reach the axle).
my stock toyota flange has more than enough angle to work, but is way too big to fit (even with major changes to the oil pan, it would still hit the transmission case).
is there a specific part (spicer or otherwise) that i can get that is both a) small enough to clear and b) has enough working angle to work properly. what are my other options (two-piece driveshaft, etc)?
what have other people with the 'short' adapter and a lift done to solve this problem?
