front output flange - interference issues
Good to know about the output shaft. Can anybody recomend a good source for a driveshaft with the smaller Nissan yoke setup, other than taking my chances with a local driveline shop?
My kit was from Advance Adapters although I can never find it on their website. You can call them or check www.sor.com they have the kit there from AA also.
Then I believe Downey http://www.downeyoff-road.com/index.html makes the kit as well.
I would send the AA adapter back and get the longer downey one (or whichever adapter actually works.
AA makes the long adapter.
Downey makes the short. I think SOR has some sort of short adapter also.
That is the downey adaptor. Even with it you need to cut the flange off the pan and dent it a little. That is why I just cut the pan. To take the pan off mine you need to remove drive shaft first. Then it comes off w/o removing the output flange.
so you have this set up working? did you have to use a different bolt in the transmission pan near where the flange is? my yoke/flange bolts will hit one of the transmission pan bolts if i dont do something creative there.
as for the driveshaft - what type of lift do you have? do you have any issues with the smaller joint binding up due to too much angle?
No I do not have the Downey adaptor on. I bought the AA adaptor thinking it was going to solve my flange clearence problem. It did not, so I sent it back.
Since a new tranny pan is only $25 I decided to try to cut and weld my own pan. It works without any leaks so far. I am still using my stock flange and stock drveshaft. A skyjacker 4" lift was also added at the same time.
Yes I looked for a bolt with the lowest profile head, for the corner of the pan, and it barely clears.
I am a little confused - are you back to running the Downey adapter, or did you change over to the AA adapter? Are you using the stock flange, or the smaller one pictured in your post above? And it *is* working with your 4" lift? What year is your fj40?
Any more pictures you could take would be great and really help me out. Thanks a ton!
if your intrested in a 2 piece w/ Pillow Block, ive got some info on what i did in my buildup .. Link In my Signiture.. near the end of the tread
I have no issues w/ Biding, and im SOA, its running almost 30 Degrees at full flex.. no CV
trevor
Neither
The photo that I posted above is of a stock flange. It fits if you cut and weld the pan.
Yes it works in my 1967 fj40. I have not had it out wheelin yet, but it drives fine. I am not smart enough to take credit for this. I read about it in buckroseau's LV build thread, and was advised that this was an option by Poser.
I will take more photos if you like, but the driveshaft is off for knuckle rebuild and new pinion seals. So it will probley be a week before I can take a pic with the driveshaft on.
Neither
i think the 1967 flange must be smaller than later models. mine is a 1972 and the stock flange is much larger. the aftermarket 'smaller' flange from downey or advance adapters is the same size as the one you have as stock. maybe i will hunt down a stock 1967 driveshaft and see how it fits. thanks for the help.
EDIT: SOR lists the 1958-1967 flange/yoke/driveshaft as being a different part than the later years. can anybody else with an early (1967 or earlier) fj40 post up a picture of their stock transfer case front output flange? thanks!
