Front License Plate (no drilling)
The Rotten Apple
I was fortunate to buy a '06 CPO 100 from PA, where a front license plate is not required. Since I live in NY where a front license plate IS required, rather then drilling holes in my "vintage" bumper I searched for a more technical solution for what was a 68K vehicle when new. After some searching, I found this on Amazon:
http://www.amazon.com/Custom-Accessories-92651-License-Mounting/dp/B000BQK56C
For these living in a state where front license plates are required, one of these brackets, along with a pair of machine screws, will enable you to mount your front license plate using the OEM threaded holes without drilling into the bumper.
http://www.amazon.com/Custom-Accesso.../dp/B000BQK56C
Can you post up some pics of these threaded holes?
I used the same bracket as up5799 on my 200 Series LC. Here's what the holes look like on mine:
And after the plate was mounted without making two new holes and using the bracket in the two existing mounting points:
HTH
Old thread I know....but had the same issue with our 2004 here in Colorado. Been rolling the dice without a front plate, and pretty sure my number was almost up. Hope it works. Thanks for sharing.
