A friend of mine has a 93 extended cab with a 3 slow and an auto. When he purchased the truck it had a set of 33's and the torsion bars cranked to the max. With it set like that he was having to replace the half shafts about every year. He decided to do a Rough Country 4" lift, front cross member drop 4" rear blocks. He had an alignment done afterwards by a reputable local alignment shop. During the alignment they replaced both inner and outer tie rod ends, pitman arm, idler arm, and a torsion bar adjuster bolt. Just prior to the lift we replaced the drivers side half shaft. After the alignment was complete the truck sits with a rake. Measuring between the top of the tire and the bottom of the fender nets a difference of 1 1/4" with the front being lower. The front axles now are level, no angle what so ever. When turning at full lock, which has been previously shortened by adjusting the bump stops, there are some loud popping noises. The noises sound like axle bind, and are very noticeable even on the new axle side. I believe that just the opposite of having the torsion bars cranked to far up is the problem. When they are up the angle is poor and the shaft is basically to short. Now the angle is fine but I think the shaft is to long due to the fact that there is no angle to them.
Is this possible or should I look for another problem. Any help would be greatly appreciated.
Thank You,
Chad P.
Thank You,
Chad P.
