That's how I did mine too. Left it on the ground and blocked the tires.Done it a few times with ratchet straps, just blocked the wheels and putting on the ebrake, no worries.
holy s***, you aren't getting under the truck are you! It looks like the only thing keeping the axle under it is the sway bar.
You should have the frame sitting on 12ton jack stands and the front axle hanging freely with the tires off of it.
Sorry for the confusion. We will change the instructions. We also have to update the instructions for the new arms. You should mount the wheels, but leave the jack stands. That way the truck is still supported but you can push the axle forwards and backwards. Jack Stands only need to be removed after the arms are back in.
And the panhard and shocks
Could of just used a jack to raise the upper end of the arms into plce
I wouldn't trust those to hold the axle from rolling further forward with the weight of the truck on it. Criticize me all you want but I would rather be safe than sorry. If you are disconnecting links from your suspension system you should have the frame on stands.
The trust is in the wheel chucks and ebrake and nothing is able move. If you are a dork, dont trust or understand the mechanics of wheel chucks and ebrake you should not even be changing the arms.
90% of the e-brakes in the NE are frozen as well as in other areas in the US. I'm sure you are aware of that and still advise trusting them?
If I'm going to crawl under a truck with disconnected linkage it's going to have to push 12ton stands through 6" of concrete to get to me. And I have no intentions of recommending anyone do otherwise.
I did mine by blocking wheels, putting jack stands under the frame and only did one arm at a time. I found that there's enough movement in the axle that it wasn't too difficult to move into position. Mind you, there were two of us pushing.
