I currently run these ICON fronts on my rig.
http://www.metaltech4x4.com/p-80-icon-08-up-land-cruiser-front-coil-over-shock-kit.aspx
Functionality-wise, they drive great paired with the 722/61029 OME rears. However, I'm noticing that the top bearing moves around or pivots which may be contributing to a noise when going over certain bumps. I know it's pivoting as I had the shop center it, but after a drive back home, the driver side shock is no longer centered. I'm talking to ICON to see whether this is normal design or if it's an install fail. I suspect the former. Maybe they wanted to distribute the cost by making these front units more universal to work with other models in the Toyota line-up? Don't know for sure and don't care to dig at this time. End of day, the thing moves around.
I may or may not start from a clean slate and go with the Radflo kit. The 2.5" piston version is $240 less than the ICON from Metaltech 4x4. How does one justify the added cost to go with the ICONs? They have very little info available whereas Radflo's got specs listed on their site (good job, Glenn).
Thoughts? Thanks.
Thoughts? Thanks.
