Ok, So I decided to take on the rotor replacement project (they are obviously warped). I had about 2 hours in the afternoon and figured it would be a piece of cake (according to most of the posts here) well after an hour and a half I decided to abort and try again another day.....
here are my questions....any help would be appreciated..99 LC 120k
1)What clips, seals, etc.... should I order and replace as I am doing this?
2)Do I unbolt the whole caliper? or just the bolts to take the front half off, since it is a 2 piece design?
3)I never did get the hub off, I loosened all the front bolts, and attempted to whack it with a brass drift so cone washers pop out and release cover? is this not right? is there a sweet spot to whack it?
I did a birf repack on my 95 LC over a year ago, but kind of forgot some of the tricks, although I do have all the tools suggested to do it. Most of the posts I read said it was a piece of cake, only one seemed to be more realistic, saying 6 hours the first time and 3.5 the second. Keep in mind I will be repeating step #6 often.
thank you,
Scott
thank you,
Scott
