This is my very first axle job so this could be a not that smart question. My outer bearing's thrust washer is grooved - see a picture below. Should I reinstall the washer same way as it was or maybe turn it 180 degrees so that the not grooved side faces the bearing? What are the dangers associated with reusing this grooved washer? Getting a new original washer is not an option now. If it is necessary to install a new one I would need to make one.
Thank you in advance for help.
