Some of you fellas maybe be interested , if you prefer air to air
take one of these bad boys
chop of these little lugs and move them closer to the radiator
remove the STD verticle braket and make a new one with T off to hold the top of cooler
chuck one of these on ya motor
get a post 90 gril so it's plastic and easier to work with than metal ones , chop the back of the lowest grill bar
NOW this is for a RHD cruiser , so mark out a hole as in pic and cut the reason I had to go under headlight is the p/s box is below on the LHS the is a gap ( it's were the p/s box would go on lhs cruiser) between the body and chassis for intake plumbing , so sides would be revearsed for LHD cruisers,
this is the lhs were a lhd p/s box in my case my plumbing went through here
you fellas get the drift
start to build a snake , obviosly it will vary for different cruiser motors
getting there
it did wriggle it's way into place as one piece but I cut a join in it to allow for engine vibration and body flex
pipe sits under factory air box
the two p/s lines that go into the ps box you can see the two the higher one has to be lowered as it hits the new piping , I just put a 90* fitting in there so the hose come in on the side works well
piped up
custom grill I made, chop that stuff
get the second grill from wreckers for $30 give it some chop and bend
a bit of tack welding
pre
getting there
piped up
pre
..thanks for the pics
Really like the mods to the front bib to fit the intercooler, very nice. I've even been thinking about a petrol powered 75 series lately.
