Bluetti just released theirs yesterday with their new AC180T which utilizes the same battery pack as the fridge. I don't need a fridge enough to wire something in permanently so this seems to make the most sense to me. With one battery charged in the fridge it's supposed to run for up to 3 days. With 2 more in the AC180T you've got potential for up to 9 days without any further charging. Adding solar to the mix means keeping it topped off indefinitely pretty easily.
Click Me
Didn't want to create a new thread, but wanted to put this out there. I bit the bullet on this Bluetti SwapSolar Ecosystem of products as the idea of hot swappable batteries between a power station and cooler for totally cordless operation was extremely appealing since I really don't need a permanent wired in solution. I received it a few days ago and have been testing it out around town and there is something that is putting out an interfering signal when powered on. I can pull the battery out while it's still mounted in the hatch and everything works as normal, but once it's powered on the TPMS won't receive readings from the sensors, occasionally the vehicle cannot detect the fob and will put the alert on the dash, but most of all the lock/unlock touch feature on the door handles works maybe 5% of the time and the fob is close to the same sometimes requiring 30-40 button presses to register. Sent an e-mail off to Bluetti to see what they say, but if we can't get it resolved somehow it'll likely go back. May try to see if I make some foil shielding to figure out exactly where the problem location is and if I can backdoor it to work for now.
