A comment about powering from the cigarette lighter. They may be 12v and 10amp. But that is the max. And in my experience running at the max continuously things, e.g. the wiring get very hot, too hot.
I recently was powering my frig via the power bank which was plugged into the cigarette lighter. Power was going to both so it was pulling at the max. I reduced the max amp the power bank would pull to 6 amps. Power would go to only the frig, then when it was not running to the power bank. The kept the wiring cooler. Also it kept the voltage more constant as the frig would see low voltage faults and shut down.
I plan to install a Victron XS 12/24 50 amp system in power mod so to emulate a solar panel. I will run it at 24v and 10 amp. That will allow the power bank to charge while the frig is running.
