Use vice grips on the part above the valve cover, and twist with a rolling motion back and forth. Put a hammer handle under the vice grips, so you can use it for leverage - pushing down on the vice grip handles will now lift up on the PCV valve with tremendous force. Done right, the grommet will come up with the PCV valve. DougM
How do you know your PCV valve it's stuck .?
I'm experienced low idle sometimes ( maybe one time per day and not really frecuent ) and that I've been read teach me about replace this and clean my IAC
It's really hard pull out the PCV .. ? someone with pics .. ?
After you get it out it should rattle when you shake it.
Hey Rock, the warming up thing was key!! That made the most difference out of everyones suggestions. Thanks guys, once again!
