Hi, Being as how I have manual steering, I keep the front end well greased. During the process I saw a small crack, I removed winch bumper and the brackets and such and saw this.
The P.o must have tried to fix this himself. *cough BUTCHER cough*
The 1 pic is the passenger outer side, directly above the perch.
One pic is the "gusset" Which I believe caused more problems than it helped.
the last pic is the inner view. There is a small crack there about 2-3" as well. The shiny nubs are whats left of the rivets holding the perch.
So how to fix?
My plan, so far (which may be wrong). Is to make either an L or U shaped piece from the crossmember to the end of the frame, and box the frame. It seems like Ideally I would remove the perch, and place the one side of the patch between the perch and bottom of the frame. Then weld it back up. Of course I'd have to do both sides.
As far as the welding goes
-Should I stitch weld? meaning 2" weld, then a small gap between?
-Is it ok to weld the perch back in place?
-How should I approach the Big crack? Weld it together? Or put a gusset plate over it?
Of course the vin# is right there too
Many of the guys here amaze me with their fabricating skills,
Please give me some help?
Oh, lastly. Will putting a 1/4" plate between the perch and the frame throw off the camber? Thanks
John
So how to fix?
John
