Wanted Found a switch (1 Viewer)
wngrog
Moderator
Canton, Mississippi
Needed. Mine does not seem to be working in any position anymore.
you can dis-assemble the back part of the switch and clean the contact plate. most likely gummed or varnished up and a cleaning with an eraser on a pencil will do the trick
Worth a try! Thanks.
I’ll still take one that works.....
The opportunities to repair , refurbish or restore and piece of Vintage Toyota History like your Rotary LIGHT switch are
few and far between . My belief is PO folks just swapped them out for your Local Phillips 66 Truck Stop variety brand one
back in the Dayz when that was the thing to do , Folks who bought Land Cruisers lived in the Mountains & Remote areas
where access to a Dealership Parts Dept. was Non-existent really . and Mail order by phone was probably not even a Idea then either ?
thats why u dont EVER see them come up used parts on MUD or Ebay etc ...........
there simply are not that many left alive , so Absolutely Try to Preserve Your UNICORN
what i have seen on the few iv Serviced , is that the machine screws on the Brass Lugs on the back can vibrate loose , and or
tarnish & corrode to the point of MAX Resistance between conductor LEEDS and the brass LUG itself .
i would get a set of fresh Stainless Steel Lug Machine scews Phillips head , and pull switch , polish Lugs good , install new SS screws
now the interesting part :
- cut back each leed or wire say 10mm , and trim to length stripped end , Presto ! Brand New Copper and a good conductors
when machine screw sinched down Very Carefully ....................
- i would say there is a solid 42.0% chance what i outlined above is the issue , and not the switch internals
BUT , ............. I could be wrong and it is inside maybe
but , remove , polish , trim , replace cost *9 cents in ss machine screws and can be done in 2.25 hours or less practiclally speaking
its worth a try , that much im certain of .....................
good luck @wngrog :)
worth trying above before opening switch body.
i just completed a Full Restore on this First Generation Wiper Rotary Switch , including going inside to polish contactys , pach with Di-Electric Grease etc.........
Note : my new 3mm stainless steel SEMS machine screws ,
- u need to obtain a Polish-out level very similar to this to properly conduct bare strand wire I LuGS electrical flow ....
Well I’ll ask the dumb question, my forte: did you check fuse?
