For Sale / Wanted To Buy (44 Viewers)
I will take the rims if they are all straight. I need to replace some bent chrome rims on my brothers 60. I need to figure out how I can get them though since they will be a little costly to ship. I can get new steel rims from Summit for $160 shipped so these will get close to that price if they are shipped I am sure.
Jeremy
Jeremy
They are straight and come with the center caps with "Toyota" in red for the rear wheels. The fronts did not have them because of the part time hubs. They have some surface corrosion as you would expect.
I want them gone so I will work with you, if you want them. $160 is cheap for rims shipped.
Yes, Summit ships for free. They are actually $130 but they are white. The chrome ones run about $210 shipped.
I will double check this weekend that my brother wants them. I have a friend that lives in Simpsonville, do you think you could drop them off at his house once I send the money? Also I am sure they will work with a 60, but can you check the BS just to be sure?
Thanks
Jeremy
I need a fan clutch for my 2f. The bull's running hot at idle. Used is good, if it works!
Thanks!
I've got one. 25 and it's yours. You can even have the water pump that came with it. It looked good.
Sounds good. I'll give you a call later today, maybe later this week.
Carp
I have a 74 fj40 rust bucket that I am trying to sell. The tub is shot, the top is circling the drain, but the cowl is good, all top glass is good, frame could be repaired.
F engine, 4speed tranny and tcase- dont know what kind of shape, but are intact.
Doors are repairable. Has drivers seat. Wiring harness is intact, but removed.Axels are on the frame. No Drive Shafts. I also have a good 78 frame. Asking $700. I am located in Gainesville, Ga. call Chris @678-936-0682.
80-Series Parts For Sale: Frankie's lift items; OEM u-joints & mudflaps, hitch, etc.
Best way to get in touch with me is by email if interested: arhowlett@gmail.com.
1/ SOLD - Pair of Frankie's Off-Road 3" Progressive Coil Front Springs - $175 (These springs are awesome compared to any OME coils I've experienced; <10k miles; Frankie's first generation production springs purchased in '07)
2/ SOLD - Set of (4) 3deg Blue Caster Correction Bushings for front control arms with Press Tool - $100 (Pressed in one time and out one time; <5k Miles; purchased in '07)
3/ SOLD - Complete OEM Front Drive Shaft with Brand New Toyota OEM U-Joints on both ends - $100 (I was hoping some new spiders would fix the vibes, but less than 500 miles later I bought the DC front shaft; I’m selling this complete shaft cheaper than one can purchase the OEM U-joints alone, not to mention they're already installed!).
4/ SOLD - Front Bump Stop Spacers - $20 (Brand new, never installed, purchased in '07 as a portion of Frankie's suspension lift; Puck measures approximately 3".)
5/ SOLD - Draw-Tite Max-E-Loader Class IV Receiver Hitch - $40 (Black powder coat, Draw-Tite part no. 41015, frame mounted, hardware included, can tow way more than an 80 ever will!)
6/ SOLD - Front Mud Flaps - $70 (perfect condition, purchased last year from CDAN)
7/ SOLD - Rear Mud Flaps - $30 (original ’97, slightly faded)
8/ OEM Stuff - Front and rear coils and shocks, steering stabilizer, fan clutch, front (SOLD) and rear bumper, front and rear ring and pinion, front and rear diff breather flappers, rear diff e-lock guard, front rotors (never turned to my knowledge but have a very slight warp, I just replaced them during the birf repack to avoid down time).
9/ Bosch 02 Sensors - Front sensor: Bosch universal Part No. 15728. Rear Sensor – Bosch 13136 (although the actual sensor has this identification: “0 258 986 606 784026 15 (12V, 982/Ao)”. Both have the factory harnesses and the Toyota flanges for the two hole exhaust bung installed and are ‘plug and play’ solutions. I only had them on the truck for about 25 miles before I received another OBDII code and replaced them both with Toyota OEM sensors. I have heard of some earlier cruisers having success with these sensors, so I figured I would post them up although I do not recommend them for a late model (‘95-‘97) cruiser.
10/ Wanted: Yes you might think I’m crazy but the only options my 40th didn’t have were the factory roof rack and the deflector above the rear glass. I like the look of both of these options, so please let me know if anyone would like to shed these items. Thanks for looking!
arhowlett@gmail.com
40x13.50x 17 MTR's & Beadlocks
Will make any club member a great deal on these. They made two trips to GSMTR. The tires speak for themselves. I have them listed in the classified section cheap so any Upstate Cruiser can get a real deal. Have 4.
If my F and 3 speed could handle turning those until i but in a 4 speed and regear I would jump on them. Love those wheels and tires. :D
Set of (4) BFG All-Terrain T/A KO 315/75R16
A set of (4) BFG All-Terrain T/A KO 315/75R16 - $500obo. Located in Greenville, SC. The rear tires have about 11k miles, and the front tires have about 8k miles - I can explain if interested. They have been rotated once at 6k after purchase. Paid over $1k mounted at Discount tire. I don't post or check PMs often; the most efficient way to contact me is via email at:
arhowlett@gmail.com
Thanks for looking!
need Linkage and stock Air Cleaner assembly For a 77' FJ40. Need all bolts and all.
I am thinking about selling my tires. They are 34x10.5 LTB's. I have 4 mounted on stock disc wheels in ok shape. I have a 5th rim with a stock cruiser tire. They will come with stock hubcaps. Tires have 500-1000 miles max on them. They still are showing the swamper logo on the tread. Tires are around $180 each new, rims $150 and caps $100. Thinking $600 OBO total? I love the tires but am seriously thinking about going larger.
Sold to Sputnik 40
WTB: fj40
WTB: fj40 in decent shape, mostly stock, prefer front discs.
New here, been looking for a mostly stock fj40 for a while now without a lot of luck. I don't mind doing the work on it but would prefer something I could drive while restoring.
I am in cola, but will travel a distance.
Any help would be appreciated.
Thanks
Joe
Jmq4@bellsouth.net
