Having got the hub back on after this front axel service the preload that has spec of 6.4-12.6 lbf is 18 lbf. One factor may be that I noticed after I had installed the oil seal over the inner bearing that I could not turn the inner bearing by hand. My manual does not say about limiting the pressure needed to put in the oil seal. I banged it home tight - was thing wrong of me? What's my problem and what do I need do before I continue to install the lock washer?
Thanks
Thanks
